Install a user certificate on a computer
Install the user certificate on the same computer where you have installed the server certificate.
- Copy the [user name].p12 file from the primary computer to the computer that needs access to the failover web console.
- Right-click the user certificate and select Install Certificate.
                  In the Certificate Import wizard, choose the Store Location: -
                      On the primary and the secondary computer, select Local Machine
                      On all other computers, select Current User.
 Select Next.
                  Browse to the certificate file and select Next.
                  Specify the password for the private key from when you created the server certificate, and select Next
                  Place the file in the Certificate Store: Personal and select Next.
                  Verify the information and select Finish to import the certificate.
                  On the primary and the secondary computer, allow the user that runs the Management Server service to use the private key of the user certificate: -
                      From the same computer, start Manage computer certificates.
                      Select Personal and Certificates, and then select the user certificate that you have just installed.
                      Right-click the certificate and select All Tasks > Manage Private Keys.
                      Add full control permission for the user that runs the Management Server service. The default user is Network Service:
                  Install the server and a user certificate on every computer that you want to use for access to the failover web console.
If you had opened the web page of the failover web console before you installed the certificates, refresh the web page.
Your browser may prompt you to select a user certificate.
