Install XProtect Smart Client
You must install XProtect Smart Client on your computer before you can use it. You download XProtect Smart Client from the surveillance system server and install it on your computer.
Milestone recommends that you always use the latest version of the XProtect Smart Client to ensure that you have access to all the new features and functions included in your XProtect surveillance system.
- Open your browser and connect to the management server using the URL or IP address of the server.
- Enter one of the following:
- Local server (http://localhost/installation)
- IP address of the remote server (http://[IP_address]/installation)
- On the Welcome page, click Language and select the language you want to use. The XProtect Smart Client setup wizard starts.
- In the wizard, follow the installation instructions. The wizard suggests an installation path. Normally, you can use the suggested installation path. However, if you have previously used add-on products, this path might not be valid anymore.
