Specify a time profile
  1. In the Time Profiles list, right-click Time Profiles > Add Time Profile. This opens the Time Profile window.
  2. In the Time Profile window, enter a name for the new time profile in the Name field. Optionally, enter a description of the new time profile in the Description field.
  3. In the Time Profile window's calendar, select either Day View, Week View or Month View, then right-click inside the calendar and select either Add Single Time or Add Recurring Time.
  4. When you have specified the time periods for your time profile, click OK in the Time Profile window. Your system adds your new time profile to the Time Profiles list. If at a later stage you wish to edit or delete the time profile, you do that from the Time Profiles list as well.
Add a single time
When you select Add Single Time, the Select Time window appears:
The Select time window overview with sample dates.
Time and date format may be different on your system.
  1. In the Select Time window, specify Start time and End time. If the time is to cover whole days, select the All day event box.
  2. Click OK.
Add a recurring time
When you select Add Recurring Time, the Select Recurring Time window appears:
The Select Recurring Time window with sample dates.
  1. In the Select Time window, specify time range, recurrence pattern and range of recurrence.
  2. Click OK.
A time profile can contain several periods of time. If you want your time profile to contain further periods of time, add more single times or recurring times.
Recurring time
When you set an action to be executed on a detailed, recurring schedule.
For example:
  • Every week on Tuesday every 1 hour(s) between 15:00 and 15:30
  • On day 15 every 3 month(s) at 11:45
  • Every day every 1 hour(s) between 15:00 and 19:00
The time is based on the local time settings of the server on which Management Client is installed.
