Specify common properties for all devices in a device group
With device groups, you can specify common properties for all devices within a given device group:
- In the Overview pane, click the device group.
In the Properties pane, all properties which are available on all of the device group's devices are listed and grouped on tabs.
- Specify the relevant common properties.
On the Settings tab, you can switch between settings for all devices and settings for individual devices.
- In the toolbar, click Save. The settings are saved on the individual devices, not in the device group.
