Create a report with incident project information
You can create a report with all the textual information added to an incident project.
When the report is created, you can print and save it. You can send the report to colleagues, the police, or others together with an export of the incident project. An export contains the sequences added to the incident project.
- Select the Incidents tab.
- Select the incident project from which you want to generate a report.
- If you want to print or save the report, select Print.
