Add additional sequences to an incident project
If you have created an incident project in real-time, you typically want to add sequences to your incident project that show what happened before the incident started.
Add one sequence at a time
- On the Live or Playback tab, select the Add to incident project icon in the bottom-right corner of the camera position from which you want to add a sequence.
- Select Add to existing incident project.
- Select Select start time and drag the timeline until you have found where the incident started.
- Select Add to incident project again to continue with selecting the end time.
- Select Select end time and drag the timeline until you have found where the incident ended.
- Select Add to incident project again and select OK.
- Select the incident project to which you want to add the sequence.
If it is difficult to find a specific incident project, you can use the filter options. See Filter for incident projects.
Add several sequences
- Select Add to draft sequence list.
- Repeat the steps above as many times as needed to get all the relevant sequences for your incident project.
- Select the Add to incident project icon and select View draft sequence list.
- Select the sequences in the draft sequence list that you want to add to your existing incident project and select Add all to existing incident project.
