Change the time zone
The default value of the time zone reflects your current physical location as detected by Milestone Customer Dashboard. You can select the time zone that you want to appear in error timestamps, in the Milestone Customer Dashboard interface, and in the reports that you create.
  1. In the upper right-hand corner, select your login name, then select User settings.
    The dropdown menu under the user name in Milestone Customer Dashboard.
  2. On the User settings page, under Language and region, select the desired time zone in the Time zone dropdown list .
    The user settings page in Milestone Customer Dashboard.
  3. Select Save to apply the changes.
