Unsubscribe from XProtect BYOL
  1. Delete the CloudFormation stack:
    1. In the AWS Management Console, open the CloudFormation service page.
    2. Select the deployed XProtect BYOL CloudFormation stack.
    3. Select Delete, and in the confirmation dialog, select Delete stack.
  2. Unsubscribe from the marketplace listing:
    1. In the AWS Management Console, open the AWS Marketplace Subscriptions service page.
    2. Select the XProtect BYOL marketplace listing.
    3. In the upper right-hand corner, select Actions > Cancel subscription.
    4. In the Cancel subscription dialog box, select the confirmation check box, then select Yes, cancel subscription.
You are now unsubscribed from XProtect BYOL.
Any services that you deploy other than those deployed by the XProtect BYOL CloudFormation, such as EBS storage services or EC2 instances, will not be removed when you unsubscribe from the marketplace listing. You must delete or terminate these services separately.
