Licenses (explained)
Free XProtect Essential+
If you have installed XProtect Essential+, you can run the system and eight device licenses for free. Automatic license activation is enabled, and hardware will be activated as you add it to the system.
Only when you upgrade to a more advanced XProtect product and need to change your SLC (Software License Code) (see Change the Software License Code), the rest of this topic and the other licensing-related topics in this documentation could be relevant for you.
Licenses for XProtect VMS products (except XProtect Essential+)
Software license file and SLCs
При покупке программного обеспечения и лицензий вы получите:
  • Подтверждение заказа и файл лицензии на программное обеспечение (SLC) с расширением .lic по электронной почте
  • Договор обслуживания Milestone Care
Your SLC is also printed on your order confirmation and consists of several numbers and letters grouped by hyphens like:
  • Product version 2014 or earlier: xxx-xxxx-xxxx
  • Product version 2016 or later: xxx-xxx-xxx-xx-xxxxxx
The software license file contains all information about your purchased VMS products, add-on products, and licenses. Milestone recommends that you store the information about your SLC and a copy of your software license file in a safe place for later use. You can also see your SLC in the License Information window in Management Client. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.You may need the software license file or your SLC when you, for example, create a My Milestone user account, contact your reseller for support, or if you need to make changes to your system.
Overall process for installation and licensing
To get started, you download the software from our website (https://www.milestonesys.com/downloads/). While you are installing (see Install a new XProtect system) the software, you are asked to provide the software license file.
Once the installation is complete and you have added some cameras, you must activate your licenses (see License activation (explained). You activate your licenses from the License Information window in Management Client. Here you can also see an overview of your licenses for all installations on the same SLC. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.
License types
В системе лицензирования XProtect несколько типов лицензий.
Базовые лицензии
У вас есть как минимум базовая лицензия на один из продуктов XProtect. У вас также могут быть базовые лицензии на дополнительные продукты XProtect.
Лицензии на устройства
У вас как минимум несколько лицензий на устройства. Вообще говоря, для каждого аппаратного устройства с камерой, подключаемого к системе, нужна одна лицензия на устройство. Однако это может зависеть от типа устройства и от того, поддерживается ли аппаратное обеспечение устройства системой Milestone. Дополнительные сведения приведены в разделах Поддерживаемые аппаратные устройства и Неподдерживаемые аппаратные устройства.
Для применения функции Video Push XProtect Mobile нужна одна лицензия на каждое мобильное устройство или планшет, которые должны передавать видео в вашу систему.
Лицензии на устройства не нужны для динамиков, микрофонов и устройств ввода-вывода, подключенных к камерам.
Вообще говоря, для каждого аппаратного устройства с камерой, подключаемого к системе, нужна одна лицензия на устройство. Однако для некоторых поддерживаемых аппаратных устройств нужно несколько лицензий. Информацию о количестве лицензий, необходимых для аппаратного устройства, приведена на сайте Milestone (https://www.milestonesys.com/supported-devices/).
Для видеокодеров до 16 каналов требуется только одна лицензия на каждый IP-адрес кодера. У видеокодера могут быть один или несколько IP-адресов.
Если у видеокодера более 16 каналов, требуется одна лицензия на каждую активированную камеру видеокодера, причем это требование распространяется и на первые 16 активированных камер.
Неподдерживаемые аппаратные устройства нуждаются в одной лицензии на каждую активированную камеру, использующую видеоканал.
Неподдерживаемые аппаратные устройства не показаны в списке поддерживаемого аппаратного обеспечения на сайте Milestone (https://www.milestonesys.com/supported-devices/).
Лицензии на камеры Milestone Interconnect™
Для работы Milestone Interconnect нужны лицензии на камеры Milestone Interconnect центрального объекта, позволяющие просматривать видео с устройств на удаленных объектах. Необходимое количество лицензий на камеры Milestone Interconnect зависит от количества устройств на удаленных объектах, с которых нужно получать данные. В качестве центрального сайта может использоваться только XProtect Corporate.
Лицензии на дополнительные продукты
Для большинства дополнительных продуктов XProtect требуются дополнительные лицензии. Файл лицензии на программное обеспечение также содержит информацию о лицензиях на дополнительные продукты. У некоторых дополнительных продуктов предусмотрены собственные файлы лицензий. Дополнительные сведения о лицензиях на дополнительные продукты приведены здесь:
  • XProtect Access (см. XProtect Access licenses)
  • XProtect LPR (см. XProtect LPR licenses)
  • XProtect Transact (см. Before you start)
  • XProtect Smart Wall нужны следующие лицензии для работы видеостены:
    • Базовая лицензия XProtect Smart Wall на неограниченное количество мониторов для просмотра видео на видеостене
    XProtect Smart Wall можно использовать только в следующих продуктах:
    • XProtect Corporate — базовая лицензия на XProtect Smart Wall входит в состав базовой лицензии
    • XProtect Expert — базовая лицензия на XProtect Smart Wall продается отдельно
