Use the filter
Filter your views
If you want to see a particular type of view only, or if you want to display fewer views, you can apply a filter. All views are displayed when you tap the filter, regardless of whether they are shown or filtered. You can always choose to include a view again.
How you filter views depends on the operating system on your device. To filter views:
  1. On the Home screen:
    • Android - In the upper-right corner, tap . If a filter is already applied, the icon has a check mark
    • iOS - In the upper-right corner, tap . If a filter is already applied, the icon is blue
  2. To include or exclude a view, tap the view or use the slider.
  3. To apply the filter and return to the list of views:
    • iOS - In the upper-right corner, tap Done
Discard filter selections
If you haven't saved your selections yet, you can discard them:
  • Android - In the upper-left corner, tap
  • iOS - Undo your selections manually
Filter your bookmarks
You can filter the list of your bookmarks by using a specific time frame with predefined time intervals between the start time and the end time of the video sequences that you have bookmarked. The default duration of the time frame is set to 2 hours.
  1. On the Bookmarks screen:
  2. On the Filter bookmarks screen, to specify the time frame:
    • Android - Select the Show specific time frame check box
    • iOS - Switch on the Show specific time frame setting
  3. To open the list of predefined time intervals:
    • Android - Tap the Predefined time intervals list
    • iOS - Tap the Predefined time intervals link
  4. Select one of the following time intervals:
    • Last 2 hours
    • Last 6 hours
    • Last 12 hours
    • Last 24 hours
    • Yesterday
    • Last 7 days
  5. To apply the filter and return to the list of bookmarks:
  6. Optional. To discard your filter selection before you have saved your changes:
    • Android - Tap
    • iOS - Tap
