Licenses (explained)
Free XProtect Essential+
If you have installed XProtect Essential+, you can run the system and eight device licenses for free. Automatic license activation is enabled, and hardware will be activated as you add it to the system.
Only when you upgrade to a more advanced XProtect product and need to change your SLC (Software License Code) (see Change the Software License Code), the rest of this topic and the other licensing-related topics in this documentation could be relevant for you.
Licenses for XProtect VMS products (except XProtect Essential+)
Software license file and SLCs
All'acquisto di software e licenze, l'utente riceverà:
  • Una conferma d'ordine e un file di licenza software con estensione .lic il cui nome è basato sul codice di licenza software dell'utente (SLC) e inviato tramite e-mail
  • Una copertura Milestone Care
Your SLC is also printed on your order confirmation and consists of several numbers and letters grouped by hyphens like:
  • Product version 2014 or earlier: xxx-xxxx-xxxx
  • Product version 2016 or later: xxx-xxx-xxx-xx-xxxxxx
The software license file contains all information about your purchased VMS products, add-on products, and licenses. Milestone recommends that you store the information about your SLC and a copy of your software license file in a safe place for later use. You can also see your SLC in the License Information window in Management Client. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.You may need the software license file or your SLC when you, for example, create a My Milestone user account, contact your reseller for support, or if you need to make changes to your system.
Overall process for installation and licensing
To get started, you download the software from our website (https://www.milestonesys.com/downloads/). While you are installing (see Install a new XProtect system) the software, you are asked to provide the software license file.
Once the installation is complete and you have added some cameras, you must activate your licenses (see License activation (explained). You activate your licenses from the License Information window in Management Client. Here you can also see an overview of your licenses for all installations on the same SLC. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.
License types
Esistono diversi tipi di licenza nel sistema di gestione delle licenze XProtect.
Licenze di base
Come requisito minimo, si dispone di una licenza di base per uno dei prodotti VMS XProtect. Si possono avere anche una o più licenze di base per i prodotti aggiuntivi XProtect.
Licenze per i dispositivi
Come requisito minimo, si dispone di diverse licenze per il dispositivo. In generale, occorre una licenza per il dispositivo per ogni periferica hardware dotata di telecamera che si desidera aggiungere al sistema. Ma questo può differire da una periferica hardware a un'altra e a seconda che la periferica hardware sia supportata da Milestone o meno. Per ulteriori informazioni, vedere Periferiche hardware supportate e Periferiche hardware non supportate.
Se si desidera utilizzare la funzione di video push in XProtect Mobile, è anche necessaria una licenza per il dispositivo per ciascun dispositivo mobile o tablet che dovrebbe essere in grado di eseguire il video push sul sistema in uso.
Non sono necessarie licenze per i dispositivi per altoparlanti, microfoni o dispositivi di input e output collegati alle telecamere.
In generale, occorre una licenza per il dispositivo per ogni periferica hardware dotata di telecamera che si desidera aggiungere al sistema. Ma alcune periferiche hardware supportate richiedono più di una licenza per il dispositivo. È possibile vedere quante licenze per il dispositivo sono richieste dalle periferiche hardware, nell'elenco dell'hardware supportato nel sito Web Milestone (https://www.milestonesys.com/supported-devices/).
Per i decodificatori video con un massimo di 16 canali, è necessaria solo una licenza per il dispositivo per ciascun indirizzo IP del decodificatore video. Un codificatore video può avere uno o più indirizzi IP.
Tuttavia, se il decodificatore video dispone di più di 16 canali, è necessaria sul decodificatore stesso una licenza per il dispositivo per ciascuna telecamera attivata, anche per le prime 16 telecamere attivate.
Una periferica hardware non supportata richiede una licenza per il dispositivo per ciascuna telecamera attivata utilizzando un canale video.
Le periferiche hardware non supportate non compaiono nell'elenco dell'hardware supportato nel sito Web Milestone (https://www.milestonesys.com/supported-devices/).
Licenze delle telecamere per Milestone Interconnect™
Per eseguire Milestone Interconnect, sono necessarie le licenze per telecamere Milestone Interconnect nel sito centrale in modo da visualizzare il video dai dispositivi hardware nei siti remoti. Il numero di licenze per telecamere Milestone Interconnect richieste dipende dal numero di dispositivi hardware nei siti remoti da cui si desidera ricevere i dati. È possibile utilizzare solo XProtect Corporate come sito centrale.
Licenze per i prodotti aggiuntivi
La maggior parte dei prodotti aggiuntivi XProtect richiede tipi di licenza aggiuntivi. Il file della licenza software contiene anche informazioni sulle licenze dei seguenti prodotti aggiuntivi. Alcuni prodotti aggiuntivi sono dotati di file di licenza software separati. È possibile trovare ulteriori informazioni sulle licenze dei prodotti aggiuntivi qui:
  • XProtect Access (vedere XProtect Access licenses)
  • XProtect LPR (vedere XProtect LPR licenses)
  • XProtect Transact (vedere Before you start)
  • XProtect Smart Wall richiede le seguenti licenze relative a video-wall:
    • Una licenza di base per XProtect Smart Wall che copre un numero illimitato di monitor che visualizzano video su un videowall
    L'uso di XProtect Smart Wall è supportato solo in questi prodotti:
    • XProtect Corporate - una licenza di base per XProtect Smart Wall è inclusa nella licenza di base
    • XProtect Expert - acquistare una licenza di base per XProtect Smart Wall separatamente
