Expand Rules and Events, right-click Analytics Events and select Add New.
In the Properties window, enter a name for the event in the Name field.
Enter a description text in the Description field if needed.
In the toolbar, click Save. You can test the validity of the event by clicking Test Event. You can continually correct errors indicated in the test and run the test as many times as you want and from anywhere in the process.
Edit an analytics event
Click an existing analytics event to view the Properties window, where you can edit relevant fields.
Edit analytics events settings
In the toolbar, go to the Tools > Options > Analytics Events tab to edit relevant settings.
No incluya ningún dato personal en su respuesta, como nombre, correo electrónico, número de teléfono, etc. En caso de que proporcione cualquier dato personal, Milestone procesará dichos datos personales de acuerdo con nuestra Política de Privacidad. Sus datos personales se eliminarán lo antes posible de acuerdo con nuestra política de privacidad.
