XProtect Smart Wall (usage)
After configuring XProtect Smart Wall, you can start working with it in XProtect Smart Client. The system administrator defines the monitors that the video wall consists of, the layout and size of the monitors, and possibly also what cameras are displayed on the monitors.
Using XProtect Smart Wall is basically about the following:
- View Smart Wall content - open the Smart Wall monitors in different displays or floating windows that you can drag onto the physical monitors of your video wall
- Displaying content on video walls - push cameras and other types of content to the video wall and share it with the other operators who are using the video wall
To change the layout of the monitors or presets
A predefined layout for an individual monitor in XProtect Smart Client. Presets contain predefined settings that determine which cameras are displayed, and how content is structured on each monitor on the video wall. that your system administrator specified, see Change the monitor layout or Change the Smart Wall preset.
You can view both live and recorded video on your video wall depending on the tab that you are currently on. If your video wall is not already up and running, you view the video wall by sending the Smart Wall monitors to your computer displays or to new floating windows. You can then drag the floating windows onto the physical monitors that are connected to your computer. See also Smart Wall display options.
- If you are using dedicated computers to run XProtect Smart Client, Milestone recommends that you also use a dedicated computer to display your video wall. This is typically the computer that the physical monitors are connected to
- To change or control what is displayed on a video wall, you must use the Smart Wall control. See also Smart Wall control (explained)
- User rights can prevent cameras from displaying video on your video wall
Steps:
- In the Views pane, expand Smart Wall.
- Expand your preferred Smart Wall definition.
- To view Smart Wall content in the main view, select the monitors one at a time.
- To view Smart Wall content in any of your displays or in a new floating window:
- Right-click the monitors, one at a time.
- Click Send view to and select one of these options:
- Primary display - opens in full screen mode in your current display
- Secondary display - opens in full screen mode in your secondary display if any
Floating window - opens in a new floating window
The Smart Wall control is a graphical representation of the video wall showing one Smart Wall definition at a time and the monitors that it consists of. The control allows you to push cameras and other types of content to the video wall.
The image displays a Smart Wall control with two monitors:
- Left monitor has a 2x2 layout
- Right monitor has a 1+5 layout
Blue items in the Smart Wall control are currently displaying content. Gray items are empty.
How does it work? Some elements you can drag directly onto the monitors in the Smart Wall control, or specific items within a Smart Wall monitor. Other elements you need to send to a video wall, for example images. See also Displaying content on video walls.
Example 1: Suppose you have a view containing the Smart Wall control and the Alarm List. An alarm goes off, and immediately you drag the alarm from the list onto any item within Monitor 1. Operators who are looking at the video wall will now see the alarm on Monitor 1.
Example 2: Suppose you have a view containing the Smart Wall control and your smart map. You select four cameras on the smart map and drag them onto Monitor 2, which has a 2x3 layout. Operators who are looking at their video wall will now see those four cameras in the first four items of Monitor 2.
If your organization has multiple video walls, you can select the video wall you need in the Smart Wall list.
The Select preset list allows you to select and activate preconfigured Smart Wallpresets
A predefined layout for an individual monitor in XProtect Smart Client. Presets contain predefined settings that determine which cameras are displayed, and how content is structured on each monitor on the video wall..
- Hover the cursor over an item. The number of the item changes to an icon that indicates the type of content. For example, a camera would indicate that the item is showing video
- Click an item to preview the content. The toolbar in the Preview window provides options for printing the content, or sending it to another video wall
The following table describes ways to view Smart Wall content in a separate window or secondary display.
Option |
Description |
| Primary display |
View content in full screen mode on the display that you are currently viewing. XProtect Smart Client remains open behind the Smart Wall content. |
| Secondary display |
View content on another display and continue to view existing content on the current display. |
| Floating window |
View content in a new floating window. This is useful, for example, if your video wall consists of multiple monitors. |
Disconnect Smart Wall monitors
You can disconnect your Smart Wall monitors, so that you can work with the video without interfering with what other operators are viewing on the video wall.
- Follow the steps described in View Smart Wall content.
For each monitor that you want to view in disconnected mode, click Disconnect Smart Wall monitor.
Changes you make are reversed when you reconnect.
Your video wall may be preconfigured to display video from certain cameras. However, you can use the Smart Wall control to push cameras and other types of content to the video wall, for example alarms
Incident defined on surveillance system to trigger an alarm in XProtect Smart Client. If your organization uses the feature, triggered alarms are displayed in views that contain alarm lists or maps., hotspots
A particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views., images, and the smart map
A map functionality that uses a geographic information system to visualize devices (for example, cameras and microphones), structures, and topographical elements of a surveillance system in geographically accurate, real-world imagery. Maps that use elements of this functionality are called smart maps..
Depending on the situation and the environment, you can combine different types of content to improve response times and effectiveness. For example, if you want to display a picture of a suspect so that people on patrol know who to look for, you can add an image. If you want to provide guidance for response measures, you can add text.
Add or change cameras on video walls
You can change the cameras that are being displayed on the monitors of your video wall. Immediately, other operators
A professional user of an XProtect client application. who are using the same video wall will see the changes.
You have set up a view that contains your Smart Wall control. See also Add Smart Wall controls to views.
Steps:
- Make sure that your video wall is running as described in .
- If your video wall is running on a different computer, open XProtect Smart Client on your current computer.
- Go to the Live or Playback tab.
- To add a camera from a view:
- To add a camera from the Cameras pane:
- In the Views pane, select the view that contains the Smart Wall control.
- In the Cameras pane, find the camera that you want to add.
Drag the camera to an item in a monitor on your Smart Wall control. The video from the camera is displayed on the associated display or physical monitor.
To verify that you added the correct camera, check the video wall or click the camera icon in the Smart Wall control. A preview appears.
Add entire views to video walls
You can share an entire view with other Smart Wall operators by sending the view to a Smart Wall monitor. What is currently being displayed on that monitor is then replaced by the content of the view containing, for example, cameras.
You have set up a view that contains your Smart Wall control. See Add Smart Wall controls to views.
Steps:
Go to the Live or Playback tab and open the view that contains your Smart Wall control.
Milestone recommends that you open the Smart Wall control in a new floating window.
In the Views pane, find the view that you want to send to the video wall.
Drag the view into an item in the preferred monitor and then release.
- To reset the monitor to its original display, or to clear the whole monitor or a specific item in the Smart Wall control, see Stop displaying content on the video wall.
Change content on video walls
You can change what is being displayed on your video wall, for example by sharing an image of a suspect. Immediately, operators
A professional user of an XProtect client application. who are watching the video wall will see the changes.
- Alarms
- Bookmarks
- Cameras or whole views
- Carousels
- Images and snapshots
An instant capture of a frame of video at a given time. - Hotspots
- HTML pages
- Maps
- Smart map
- Text
Text and cameras you can drag into your Smart Wall control. However, before you can add other types of content to your video wall, make sure that the content has been added to a view. See Add cameras and other items to views.
Steps:
Open the view that contains the element that you want to add.
If you want to add cameras, you can drag the cameras directly from the Cameras pane. To add text, in your text editor, select the text and drag the text into an item in your Smart Wall control.
Hover over the view item. The camera toolbar appears.
- Click Send to Smart Wall and select the video wall.
Select the monitor and finally the item inside the monitor.
The associated display or physical monitor is updated accordingly.
Display text on video walls
Displaying text on your video wall is useful when you want to provide information to operators who are using the video wall.
- To send text from an existing view, first you must add the text to a view. See Add cameras and other items to views
- To add text using drag-and-drop, make sure that your text editor supports drag-and-drop operations
Steps:
- To add text from a third-party text editor:
- Open the view that contains your Smart Wall control.
- Write the text in your preferred text editor.
- Select the text.
- Drag and drop the text into an item in a Smart Wall monitor.
- In the window that appears, you can edit the text even further. Click Save.
- Immediately after, the text appears on the associated display or physical monitor.
- To add text that has already been added to a view:
- Open the view that contains the text.
- Click More > Send to Smart Wall and then select the preferred video wall.
Select the monitor and finally the position inside the monitor.
XProtect Smart Wall and alarms (explained)
You can share a prioritized overview of all alarms by adding the Alarm List to a video wall. This allows you to view and work with details about the alarm directly from the video wall. See also Displaying content on video walls.
You can also display individual alarms on your video wall by dragging and dropping the alarm from the Alarm List.
- The time of day when the event
A predefined incident occurring on the surveillance system; used by the surveillance system for triggering actions. Depending on surveillance system configuration, events may be caused by input from external sensors, by detected motion, by data received from other applications, or manually through user input. The occurrence of an event could, for example, be used for making a camera record with a particular frame rate, for activating outputs, for sending e-mails, or for a combination thereof. triggered the alarm - The name and video feed from the device that triggered the alarm, and all devices that are related to it
- You can view additional details and change some settings for the alarm by clicking the arrow in the upper right part of the position in the view. The details are as follows:
- The person the alarm is assigned to, its priority, and the state of the alarm. You can change these if you want to
- The source, or what triggered the alarm, such as when a camera detects motion or an analytics event occurs
- Instructions on how to respond to the alarm
- Activities. These are comments that users entered. Typically, they indicate decisions or actions related to the alarm. Additionally, when someone changes the details of the alarm, the system adds the changes to the list of activities
- If you were recording video when the event occurred, you can view the video of the moment the alarm was triggered by clicking the Playback tab, and then Go To Alarm Time
Send bookmarks to video walls
Sending a bookmark
An important point in a video recording, marked and optionally annotated so that you and your colleagues will easily be able to find it later. to a video wall can help you quickly share a still image or a video sequence of an incident, for example a suspicious person, with operators who are watching the video wall.
Steps:
- Create a bookmark as described in Add or edit bookmarks or Bookmark search results.
In the window that appears, click Display on Smart Wall and select the preferred video wall.
- Select a monitor and then an item within the monitor.
- To send a still image instead of the video sequence, select the Send still image only check box.
- Click OK to save your changes. The bookmarked video sequence appears on the associated physical monitor.
XProtect Smart Wall and smart map (explained)
If you are using XProtect Smart Wall, you can view the smart map
A map functionality that uses a geographic information system to visualize devices (for example, cameras and microphones), structures, and topographical elements of a surveillance system in geographically accurate, real-world imagery. Maps that use elements of this functionality are called smart maps. on your video wall and share it with other operators who are using the same video wall. The current zoom level, the location that you have navigated to, and the layers that are visible are maintained when sent to a video wall.
Drag cameras from maps or smart maps to video walls
If a particular camera on your map or smart map
A map functionality that uses a geographic information system to visualize devices (for example, cameras and microphones), structures, and topographical elements of a surveillance system in geographically accurate, real-world imagery. Maps that use elements of this functionality are called smart maps. recorded an incident, and you want to share the video from that camera, you can drag the camera from the map to the monitors of your video wall.
You can also drag cameras from maps in floating windows and secondary displays.
You can stop displaying content on a video wall, for example when an incident is under control or the content is no longer relevant.
- In your Smart Wall control, go to the monitor that you want to clear.
- Click the
icon. - Select Clear view. On the Smart Wall control, the items turn gray, and all content is removed from the Smart Wall display.
If you have removed content from a monitor, you can make it reappear by re-applying the preset
A predefined layout for an individual monitor in XProtect Smart Client. Presets contain predefined settings that determine which cameras are displayed, and how content is structured on each monitor on the video wall. that is associated with the monitor.
Other operators
A professional user of an XProtect client application. can manually change the content on a Smart Wall, and the content can change according to a schedule or rules. This means that the content that you remove can reappear later. To permanently prevent content from displaying, contact your system administrator.
Reset Smart Wall monitor after removing content
Steps:
- Click Select preset.
- Hover over the preset that corresponds to the monitor that you cleared.
Click Activate. The gray items in the Smart Wall control turn blue again.
