Denna sida är ännu inte tillgänglig på ditt språk.
Set number of cameras allowed during search
You can configure how many cameras the operators can add to a search in XProtect Smart Client. The default value is 100. If exceeding the camera limit, the operator receives a warning.
In XProtect Management Client, expand the node.
Select the relevant Smart Client profile.
Click the General tab.
In the Cameras allowed during search, select one of these values:
Please do not include any personal data in your response, such as name, email, phone number etc. Should you provide any personal data, Milestone will process such personal data in accordance with our Privacy Policy. Your personal data will be deleted as soon as possible in accordance with our Privacy Policy.
