Ta strona nie jest jeszcze dostępna w Twoim języku.
Show/edit port numbers
Right-click the Mobile Server Manager icon and select Show/edit port numbers.
To edit the port numbers, enter the relevant port number. You can indicate a standard port number for HTTP connections or a secured port number for HTTPS connections, or both.
Please do not include any personal data in your response, such as name, email, phone number etc. Should you provide any personal data, Milestone will process such personal data in accordance with our Privacy Policy. Your personal data will be deleted as soon as possible in accordance with our Privacy Policy.
