Enable Bing Maps or Google Maps in XProtect Smart Client
To allow XProtect Smart Client operators to use a different key than the key from the Smart Client profile, you must enter the key in the settings in XProtect Smart Client.
Steps:
  1. In XProtect Smart Client, open the Settings window.
  2. Click Smart map.
  3. Depending on the map service you want to use, do one of the following:
    • For Bing Maps, enter your key in the Bing Maps key field
    • For Google Maps, enter your key in the Private key for Google Maps field
