Enable Bing Maps or Google Maps in Management Client
You can make a key available to multiple users by entering it for a Smart Client profile in Management Client. All users who are assigned to the profile will use this key.
Steps:
- In Management Client, on the Site Navigation pane, click Smart Client Profiles.
- In the Smart Client Profiles pane, select the relevant Smart Client profile.
- In the Properties pane, click the Smart map tab:
- For Bing Maps, enter your Basic Key or Enterprise Key in the Bing Maps key field
- For Google Maps, enter your Maps Static API key in the Private key for Google Maps field
- To prevent XProtect Smart Client operators from using a different key, select the Locked check box.
