Ta strona nie jest jeszcze dostępna w Twoim języku.
Camera angles
Single-line rule: Mount the camera so that you can draw a horizontal line that crosses both the left and right edge of the license plate in the captured images. See the illustrations below for correct and incorrect angles for recognition.
Vertical angle: The recommended vertical view angle of a camera used for LPR is between 15°-30°.
Horizontal angle: The recommended maximum horizontal view angle of a camera used for LPR is between 15°-25°.
Please do not include any personal data in your response, such as name, email, phone number etc. Should you provide any personal data, Milestone will process such personal data in accordance with our Privacy Policy. Your personal data will be deleted as soon as possible in accordance with our Privacy Policy.
