Mobile Server Manager (explained)
The Mobile Server Manager is a tray-controlled feature connected to the mobile server. Right-clicking the Mobile Server Manager tray icon in the notification area opens a menu from which you can access the mobile server functionalities.
You can:
- Access XProtect Web Client
- Start, stop and restart Mobile Server service
- Change data protection password
- Fill in/edit management server address
- Show/edit port numbers
- Enable encryption on the mobile server using the Server Configurator
- Open today's log file (see Accessing logs and investigations (explained))
- Open Log folder (see Accessing logs and investigations (explained))
- Open investigations folder (see Accessing logs and investigations (explained))
- Change investigations folder
- See XProtect Mobile Server status (see Show status (explained))
