Licenses (explained)
Free XProtect Essential+
If you have installed XProtect Essential+, you can run the system and eight device licenses for free. Automatic license activation is enabled, and hardware will be activated as you add it to the system.
Only when you upgrade to a more advanced XProtect product and need to change your SLC (Software License Code) (see Change the Software License Code), the rest of this topic and the other licensing-related topics in this documentation could be relevant for you.
Licenses for XProtect VMS products (except XProtect Essential+)
Software license file and SLCs
Cuando adquiera su software y licencias, recibirá:
- Una confirmación de pedido y un archivo de licencia de software nombrado como su SLC (código de licencia de software) y con la extensión “.lic”, por correo electrónico;
- Y cobertura de Milestone Care.
Your SLC is also printed on your order confirmation and consists of several numbers and letters grouped by hyphens like:
- Product version 2014 or earlier: xxx-xxxx-xxxx
- Product version 2016 or later: xxx-xxx-xxx-xx-xxxxxx
The software license file contains all information about your purchased VMS products, add-on products, and licenses. Milestone recommends that you store the information about your SLC and a copy of your software license file in a safe place for later use. You can also see your SLC in the License Information window in Management Client. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.You may need the software license file or your SLC when you, for example, create a My Milestone user account, contact your reseller for support, or if you need to make changes to your system.
Overall process for installation and licensing
To get started, you download the software from our website (https://www.milestonesys.com/downloads/). While you are installing (see Install a new XProtect system) the software, you are asked to provide the software license file.
Once the installation is complete and you have added some cameras, you must activate your licenses (see License activation (explained). You activate your licenses from the License Information window in Management Client. Here you can also see an overview of your licenses for all installations on the same SLC. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.
License types
Hay varios tipos de licencia en el sistema de licencias de XProtect.
Licencias básicas
Como mínimo, tiene una licencia base para uno de los productos VMS de XProtect. También puede tener una o más licencias base para productos add-on para XProtect.
Licencias de dispositivo
Como mínimo, tiene varias licencias de dispositivos. Por lo general, necesita una licencia de dispositivo por cada dispositivo de hardware con una cámara que se quiera añadir al sistema. Pero esto puede variar de un dispositivo de hardware a otro y dependiendo de que el dispositivo de hardware sea un dispositivo de hardware soportado o no de Milestone. Si desea más información, consulte Dispositivos de hardware compatibles y Dispositivos de hardware no compatibles.
Si desea utilizar la función push de vídeo en XProtect Mobile, también necesita una licencia de dispositivo por cada dispositivo móvil o tableta que pueda enviar vídeo push a su sistema.
No necesita licencias para altavoces, micrófonos, o dispositivos de entrada y salida que estén conectados a sus cámaras.
Por lo general, necesita una licencia de dispositivo por cada dispositivo de hardware con una cámara que se quiera añadir al sistema. Pero algunos dispositivos de hardware compatibles requieren más de una licencia de dispositivo. Puede ver cuántas licencias de dispositivo requieren sus dispositivos de hardware, en la lista de hardware compatible en la página web de Milestone (https://www.milestonesys.com/supported-devices/).
Para los codificadores de vídeo de hasta 16 canales, sólo se necesita una licencia de dispositivo por dirección IP de codificador de vídeo. Un decodificador de vídeo puede tener una o varias direcciones IP.
Sin embargo, si el codificador de vídeo tiene más de 16 canales, se requiere una licencia de dispositivo por cada cámara activada en el codificador de vídeo, también para las primeras 16 cámaras activadas.
Un dispositivo de hardware no compatible requiere una licencia de dispositivo por cada cámara activada que utilice un canal de vídeo.
Los dispositivos de hardware no compatibles no aparecen en la lista de hardware compatible en el sitio web de Milestone (https://www.milestonesys.com/supported-devices/).
Licencias de cámara para Milestone Interconnect™
Para ejecutar Milestone Interconnect, necesita Milestone Interconnect licencias de cámaras en su sitio central para ver vídeo de los dispositivos de hardware en sitios remotos. El número de Milestone Interconnect licencias de cámara necesarias depende del número de dispositivos de hardware en los sitios remotos de los que se desea recibir datos. Únicamente XProtect Corporate puede desempeñar la función de ubicación central.
Licencias de productos add-on
La mayoría de los productos add-on de XProtect requieren tipos de licencias adicionales. El archivo de licencia de software también incluye información sobre sus licencias para productos add-on. Algunos productos add-on poseen sus propios archivos de licencia de software independientes.
- XProtect Access (consulte XProtect Access licenses)
- XProtect LPR (consulte XProtect LPR licenses)
- XProtect Transact (consulte Before you start)
XProtect Smart Wall precisa las siguientes licencias relacionadas con panel de vídeo:
- Una licencia básica para XProtect Smart Wall que cubre un número ilimitado de monitores que muestran vídeo en un panel de vídeo
El uso de XProtect Smart Wall únicamente es compatible con los siguientes productos:
XProtect Corporate - una licencia básica para XProtect Smart Wall está incluida en la licencia básica.
XProtect Expert - comprar una licencia básica para XProtect Smart Wall por separado.
