Manage manual recording
Stop manual recording after is enabled by default with a recording time of five minutes. This is to ensure that the system automatically stops all recordings started by the XProtect Smart Client users.
- In the Site Navigation pane, select Devices.
- Select the relevant device in the Overview pane.
- On the Record tab, select or clear the Stop manual recording after check box.
When you enable it, specify a recording time. The number of minutes you specify must be sufficiently large to accommodate the requirements of the various manual recordings without overloading the system.
Add to roles:
You must grant the right to start and stop manual recording to the client users on each camera in Roles on the Device tab.
Use in rules:
The events you can use when you create rules related to manual recording are:
- Manual Recording Started
- Manual Recording Stopped
