Denna sida är ännu inte tillgänglig på ditt språk.
Specify preset positions in a patrolling profile
In the Site Navigation pane, select Devices and then select Cameras.
Select the relevant PTZ camera in the Overview pane.
On the Patrolling tab, select the patrolling profile in the Profile list:
Click Add.
In the Select PTZ Preset dialog box, select the preset positions for your patrolling profile:
Click OK. The selected preset positions are added to the list of preset positions for the patrolling profile:
The camera uses the preset position at the top of the list as the first stop when it patrols according to the patrolling profile. The preset position in the second position from the top is the second stop, and so forth.
Please do not include any personal data in your response, such as name, email, phone number etc. Should you provide any personal data, Milestone will process such personal data in accordance with our Privacy Policy. Your personal data will be deleted as soon as possible in accordance with our Privacy Policy.
