Licenses (explained)
Free XProtect Essential+
If you have installed XProtect Essential+, you can run the system and eight device licenses for free. Automatic license activation is enabled, and hardware will be activated as you add it to the system.
Only when you upgrade to a more advanced XProtect product and need to change your SLC (Software License Code) (see Change the Software License Code), the rest of this topic and the other licensing-related topics in this documentation could be relevant for you.
Licenses for XProtect VMS products (except XProtect Essential+)
Software license file and SLCs
När du köper din programvara och licenser får du:
  • En beställningsbekräftelse och en fil för software-licens med .lic-filändelsen och ett namn baserat på din programlicenskod (SLC) via e-post
  • Ett Milestone Care-avtal
Your SLC is also printed on your order confirmation and consists of several numbers and letters grouped by hyphens like:
  • Product version 2014 or earlier: xxx-xxxx-xxxx
  • Product version 2016 or later: xxx-xxx-xxx-xx-xxxxxx
The software license file contains all information about your purchased VMS products, add-on products, and licenses. Milestone recommends that you store the information about your SLC and a copy of your software license file in a safe place for later use. You can also see your SLC in the License Information window in Management Client. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.You may need the software license file or your SLC when you, for example, create a My Milestone user account, contact your reseller for support, or if you need to make changes to your system.
Overall process for installation and licensing
To get started, you download the software from our website (https://www.milestonesys.com/downloads/). While you are installing (see Install a new XProtect system) the software, you are asked to provide the software license file.
Once the installation is complete and you have added some cameras, you must activate your licenses (see License activation (explained). You activate your licenses from the License Information window in Management Client. Here you can also see an overview of your licenses for all installations on the same SLC. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.
License types
Det finns flera licenstyper i XProtect licensieringssystem.
Baslicenser
Som minimum har du en baslicens för en av XProtect VMS-produkterna. Du han också ha en eller fler baslicenser för XProtect tilläggsprodukter.
Enhetslicenser
Som minimum har du flera enhetslicenser. Generellt behöver du en enhetslicens per hårdvaruenhet med kamera som du vill lägga till i ditt system. Detta kan dock skilja sig mellan hårdvaruenheter och bero på om hårdvaruenheten stöds av Milestone eller inte. För mer information, se Hårdvaruenheter med stöd och Hårdvaruenheter utan stöd.
Om du vill använda funktionen video push i XProtect Mobile behöver du också en enhetslicens per mobil enhet eller tablet som ska kunna skicka video till ditt system.
Enhetslicenser är inte ett krav för högtalare, mikrofoner, eller I/O- enheter anslutna till dina kameror.
Generellt behöver du en enhetslicens per hårdvaruenhet med kamera som du vill lägga till i ditt system. Ett fåtal hårdvaruenheter som stöds kräver dock mer än en enhetslicens. Du kan se hur många enhetslicenser dina hårdvaruenheter kräver i listan över hårdvara som stöds på Milestones webbsida (https://www.milestonesys.com/supported-devices/).
För videoomkodare med upp till 16 kanaler behöver du bara en enhetslicens per videoomkodares IP-adress. En videoomkodare kan ha en eller fler IP-adresser.
Om din videoomkodare har mer än 16 kanaler, krävs dock en enhetslicens per aktiverad kamera på videoomkodaren - även för de första 16 aktiverade kamerorna.
En hårdvaruenhet utan stöd kräver en enhetslicens per aktiverad kamera som använder en videokanal.
Hårdvaruenheter utan stöd visas inte i listan över hårdvara med stöd på Milestones webbsida (https://www.milestonesys.com/supported-devices/).
Kameralicenser för Milestone Interconnect™
För att köra Milestone Interconnect behöver du Milestone Interconnect kameralicenser på din centrala plats för att visa video från hårdvaruenheter på fjärrplatser. Antalet Milestone Interconnect kameralicenser som krävs beror på antalet hårdvaruenheter på fjärrplatserna som du vill mottaga data från. Notera att endast XProtect Corporate kan agera som central plats.
Licenser för tilläggsprodukter
De flesta XProtect tilläggsprodukter kräver ytterligare licenstyper. Filen för software-licensen inkluderar även information om dina licenser för tilläggsprodukter. Vissa tilläggsprodukter har sina egna separata mjukvarulicensfiler. Du kan hitta mer information om tilläggsproduktslicenser här:
  • XProtect Access (se XProtect Access licenses)
  • XProtect LPR (se XProtect LPR licenses)
  • XProtect Transact (se Before you start)
  • XProtect Smart Wall kräver följande videoväggsrelaterade licenser:
    • En baslicens för XProtect Smart Wall som täcker ett obegränsat antal bildskärmar som visar video på en videovägg
    Användning av XProtect Smart Wall har bara stöd i dessa produkter:
    • XProtect Corporate - en baslicens för XProtect Smart Wall inkluderas i baslicensen
    • XProtect Expert - köp en baslicens för XProtect Smart Wall separat
