Install secure tunnel server environment for One-Click camera connection
Before you can use Axis One-click Camera Connection, you must first install a suitable ST server environment. To work with secure tunnel server (ST server) environments and Axis One-click cameras, you must first contact your system provider to obtain the needed user name and password for Axis Dispatch Services.
Requirements
  1. On each camera's homepage, go to Basic Setup, TCP/IP, and select Enable AVHS and Always.
  2. From your management server, go to the Milestone download page (https://www.milestonesys.com/downloads/) and download the AXIS One-Click software. Run the program to setup a suitable Axis secure tunnel framework.
