Encrypt your recordings
Available functionality depends on the system you are using. See https://www.milestonesys.com/solutions/platform/product-index/ for more information.
You can secure your recordings by enabling encryption on your recording servers' storage and archives. You can choose between light and strong encryption. When you enable encryption, you must also specify a related password.
Enabling or changing encryption settings or password can potentially be time consuming, depending on the size of the database and performance of the drive. You can follow the progress under Current Tasks.
Do not stop the recording server while this task is ongoing.
  1. Click the Edit Recording Storage button below the Recording and archiving configuration list.
  2. In the dialog box that appears, specify encryption level.
  3. You are automatically directed to Set Password dialog box. Enter password and click OK.
