Delete an archive from a storage
- Select the archive from the Recording and archiving configuration list.
 - Click the
 button located below the Recording and archiving configuration list. - Click Yes.
 - If the archive is unavailable, for example, offline, you need to restore the connection before you can delete the archive.
It is only possible to delete the last archive in the list. The archive does not have to be empty.
