Milestone ONVIF drivers
Milestone is currently certified with ONVIF profiles S, T, G and Q (see also Section 2 – ONVIF certification ) and has created standard drivers to facilitate the integration of compliant devices into XProtect.
This Driver Overview document defines the settings, features, events and profiles that ONVIF and ONVIF16 channel driver support. There are in details which settings are dynamic, how drivers handle the events, what is necessary to be set up in order some functionalities to work.
Milestone constantly updates and adds new functionality to our ONVIF drivers, making sure that they are compliant with the most recent official ONVIF specifications.
Note: A device fully compliant to ONVIF profiles S, T, G or Q will likely work with Milestone XProtect, and be able to send and receive video, audio and configuration data – however it will not necessarily be directly supported by Milestone Technical Support.
In case of any issues, please note Milestone Technical Support services cover only the devices our driver teams have worked to test directly. For more information, please check the Supported Device list.
