FAQ: alarms
Go to the Alarm Manager tab and look in the alarm list. If you do not see the alarm, it may have been filtered out. Try changing the filter settings.
If the alarm list is configured to show events instead of alarms, click the Setup button. In the Properties pane on your left-hand side, select Alarm in the Data Source list and click Setup again.
