Update site information of child sites
This section is only relevant if you use XProtect Corporate
In a large Milestone Federated Architecture setup with a lot of child sites, it is easy to loose the overview and it can be difficult to find the contact information to the administrators of each child site.
Therefore you can add additional information to each child site and this information is then available for the administrators on the central site.
You can read the information about the site, when you pause your mouse over the site name in the Federated Site Hierarchy pane. To update information about the site:
- Log into the site.
- Click Site Navigation pane and select Site Information.
- Click Edit and add the relevant information in each category.
