Tato stránka zatím není k dispozici ve vašem jazyce.
XProtect LPR licenses
XProtect LPR requires the following LPR-related licenses:
  • A base license for XProtect LPR that covers an unrestricted number of LPR servers
  • One LPR camera license per LPR camera you want to use in XProtect LPR
  • A LPR country module license for each country, state or region you need in your XProtect LPR solution. Five LPR country module licenses are included with the XProtect LPR base license. All country modules are automatically installed when you install your XProtect LPR product. However, the installed modules are by default disabled and you must enable the modules (see Country modules tab) that you want to use. You can only enable as many country modules as you have LPR country module licenses for
Example: You have five LPR country module licenses and you have installed 10 country modules. Once you have selected five country modules, you cannot select any more. You must clear some of your selections before you can select other modules.
To find information about the current status of your licenses, see View LPR server information.
To buy additional LPR-related licenses or country modules, contact your vendor.
