Upgrade in a workgroup setup
If you do not use a domain setup, but a workgroup setup, you must do the following when you upgrade:
- On the recording server, create a local Windows user.
- From the Windows Control Panel, find the Data Collector service. Right-click it, select Properties, and select the Log on tab. Set the Data Collector service to run as the local windows user you just created on the recording server.
- On the management server, create the same local Windows user (with the same user name and password).
- In the Management Client, add this local Windows user to the Administrator's group.
For installing with workgroups, see Installation for workgroups.
