Installation for workgroups
If you do not use a domain setup with an Active Directory server, but a workgroup setup, do the following when you install:
                                Log in to Windows using a common administrator account. Make sure to use the same account on all computers in the system.
- Depending on your needs, start the management or recording server installation and click Custom.
- Depending on what you selected in step 2, select to install the Management Server or Recording Server service using a common administrator account.
- Finish the installation.
- Repeat steps 1-4 to install any other systems you want to connect. They must all be installed using a common administrator account.
You cannot use this approach when you upgrade workgroup installations. See instead Upgrade in a workgroup setup.
