XProtect Web client
Remove unnecessary cameras from video playback
Version2026 R2
LanguageEnglish
"Before I play back the video, I want to remove the cameras that don’t contain any recordings within the time span that I’ve specified. How can I do that?"
On the Investigations tab, you can remove the unnecessary cameras from a camera group if you:
  • Hover over the camera and then, in the upper right-hand corner, click WebC_remove_camera.png.
  • On the side panel, click WebC_camera-added_remove-camera.png.
  • On the side panel, double-click the camera that you want to remove.
