XProtect Web client
Home page overview
Version2026 R2
LanguageEnglish
On the top menu bar, you can use these tabs to do the following:
Item in menu
What can I do with it?
Milestone logo
Click to return to the Home page of XProtect Web Client.
Views
Investigations
Actions
Activate actions, for example, to open doors (see Activate actions).
Alarms
View alarms from all cameras (see View alarms).
Bookmarks
View the list of bookmarks (see Bookmarks).
If you want to exit XProtect Web Client, click WebC-UserMenu_icon_2022r2.png, then select Log out.
Click the More menu to:
  • Select Settings and customize XProtect Web Client (see Settings).
  • Select Learn more to go to the documentation portal and read more about XProtect Web Client.
  • Select Restart the guided tour to view tutorials about the most important new features in XProtect Web Client.
The left pane is collapsible. To collapse the pane, click WebC_LeftPane_CollapseButton_I.png. You can also adjust the pane borders by dragging them to the left-hand or right-hand side.
In the pane, you can go to these pane sections to do the following:
Item in menu
Search for cameras and views
Find a folder, view, or camera by entering their name. You can also search for a camera by entering keywords from the camera description defined in XProtect Management Client. You can filter out the irrelevant items from the list of views. The relevant matches are highlighted (see Search for camera).
Views
View videos from one or multiple cameras in live or playback mode. The Views pane section has a Show / Hide option. The Private and Public folders contain lists with subfolders with views inside.
Cameras
View videos from one camera in live or playback mode. The Cameras pane section has a Show / Hide option. The camera groups and the related devices are organized in lists with folders with cameras inside.
