XProtect Web client
Playing back audio in video recordings
In XProtect Web Client, you can:
  • Play back audio from camera recordings in playback mode.
  • Play back audio from camera recordings in investigations.
On the camera toolbar:
  • To listen to the recorded incoming audio, click MobC_audio_inactive.png to start playing the audio while playing back the video recording.
  • To listen to the recorded incoming audio and outgoing audio, click MobC_audio_inactive.png to start playing the audio. From the Audio source list, select the audio device that you want to listen to while playing back the video recording. The options are:
    • All sources (default) - listen to both the recorded incoming and the outgoing audio
    • Microphone - listen to the incoming audio only
    • Speaker - listen to the outgoing audio only
Note
You can play back audio only when there is a video recording and you play the recording forward at normal speed.
