XProtect Web client
Requirements for listening to incoming audio
Version2025r3
LanguageEnglish
To listen to incoming audio from your cameras, you must have:
  • A microphone attached to a camera.
    Note
    When a camera in your surveillance system has a microphone attached, you can play audio without any additional settings needed. The audio icon on the camera toolbar shows whether the audio feature is available.
  • Sufficient user permissions.
    Note
    Access to the incoming audio feature may be restricted depending on your user permissions.
