XProtect Transact for admins
XProtect Transact trial license
Version2026 R2
LanguageEnglish
With an XProtect Transact trial license, you can try out the XProtect Transact functionality up to 30 days. All related features are enabled, and you can add one transaction source, for example a cash register. When the 30 days trial period expires, all XProtect Transact features are deactivated, including the Transact workspace and transaction view items. By purchasing and activating an XProtect Transact base license and the transaction source licenses you need, you can use XProtect Transact again, and your settings and data are maintained.
You need to acquire the trial license from Milestone. The system administrator must activate the trial license in the configuration.
