XProtect Transact for admins
Transaction definitions
Version2025r3
LanguageEnglish
A transaction definition is a group of settings that help you control how raw data from the transaction sources are displayed in XProtect Smart Client together with the video recordings. The output is a reader-friendly format that resembles real-life receipts, for example till receipts and receipts from automated teller machines.
More specifically, transaction definitions let you:
  • Define when the individual transactions begin and end
  • Insert line breaks as required
  • Filter out unwanted characters or text strings, for example if the data comes from a printer connection and contains unprintable characters for indicating line breaks, when to cut off a till receipt
  • Substitute characters with other characters
Note
You can use the same transaction definition on multiple transaction sources.
