Configuring XProtect Smart Wall
After doing the initial configuration in XProtect Management Client, operators can start using the video wall by sending the Smart Wall monitors onto the physical monitors connected to the system. This may include one or both of these options:
Static views
Views that change dynamically based on rules
Additional configuration is necessary if you want to:
Enable operators to control and manually change what is being displayed on the physical monitors. In that case, you must add the Smart Wall control to designated views.
Change the existing view layout of individual monitors.
Reset or change the preset already applied to the Smart Wall definition.
