XProtect Smart Wall for admins
Test your Smart Wall configuration
Version2026r2
LanguageEnglish
After configuring XProtect Smart Wall in XProtect Management Client, you may want to test the configuration before you start adding the Smart Wall control to your views in XProtect Smart Client.
Steps:
  1. Log in to XProtect Smart Client.
  2. In the Views pane, expand the Smart Wall node.
  3. Select a Smart Wall definition and then one of its monitors. If correctly configured, the main view shows the cameras that the preset is configured to show.
    View Smart Wall monitor in the main view of XProtect Smart Client.
The example shows a monitor with two cameras.
