XProtect Smart Wall for admins
Get started
Before you can start using XProtect Smart Wall, you need to:
  1. Get and activate a base license for XProtect Smart Wall. See also XProtect Smart Wall licensing.
  2. Configure XProtect Smart Wall and set the user permissions in XProtect Management Client. See also Configuring XProtect Smart Wall and Specify user permissions for XProtect Smart Wall.
  3. Optionally, you can make the XProtect Smart Wall control available to operators in XProtect Smart Client. See also Configuring XProtect Smart Wall.
