Terminology related to Smart Wall
Term | Meaning |
Smart Wall definition | The configuration of a video wall in XProtect Management Client, including the setup of Smart Wall monitors and presets. ![]() |
Smart Wall monitor | The virtual representation of a physical monitor. In most cases, we need to distinguish between physical monitors and Smart Wall monitors. ![]() The image shows the Smart Wall control in XProtect Smart Client. |
Smart Wall control | The virtual representation of a video wall that allows operators to push content onto the video wall. ![]() |
Preset | A predefined layout for one or more Smart Wall monitors. Presets determine which cameras are displayed, and how content is laid out on each monitor on the video wall. ![]() NoteIf you come across the term "preset" in the context of PTZ cameras, then it has a different meaning and refers to the concept preset position. |
View | A grouping of cameras or other elements, for example webpages, that allows operators to view video from related cameras and other types of content. ![]() |
View item | A position within a view that typically holds a camera. ![]() |
Preset item | A view item where its default content depends on the configuration of the underlying preset. ![]() |
View layout | The layout of a Smart Wall monitor that defines how to arrange the view items, for example 2x3 or 1+2. ![]() |
