XProtect Incident Manager
Note
If you have access to XProtect Incident Manager functionality in XProtect Smart Client, you can start an incident project under the MIP plug-ins pane and find existing incident projects on the Incidents tab. The presence of an Incidents tab alone doesn’t indicate if you have access to the functionality offered by the XProtect Incident Manager extension.
The XProtect Incident Manager extension is compatible with:
XProtect Corporate version 2022 R2 and later
XProtect Expert, XProtect Professional+, and XProtect Express+ version 2022 R3 or later
XProtect Smart Client version 2022 R2 and later
