View status details on maps
Version2026 R2
LanguageEnglish
Status details are available for cameras (for example, resolution, image size, and bit-rate) and servers (for example, CPU usage, memory, network usage).
  • To display status details, right-click the required element and select Status details. Status details are displayed in a separate, floating window
Note
If you see an error message saying that the event server has insufficient access permissions to the recording servers, you will not be able to view status details from recording servers. The error message relates to the Event Server service, which handles map-related communication on the XProtect VMS system. The Event Server service is managed on the XProtect VMS system server. Contact your system administrator, who will be able to handle the issue.
