Transfer the search time to the main timeline
Version2026 R2
LanguageEnglish
When you are previewing a search result on the Search tab, you can synchronize the time in main timeline with the time in the search timeline. This is useful if, for example, you have found an incident, and you want to investigate what happened at that time on other cameras.
  1. On the Search tab, select a search result.
  2. In the preview area, click SC_SynchronizeTimeToPlaybackTimeline.jpg to transfer the current time in the search timeline to the main timeline. You will stay on the Search tab.
    Transfer current time to the playback timeline in XProtect Smart Client.
  3. To check other related cameras, switch to playback mode and select a view that contains the cameras that you are interested in. The main timeline is now in sync with the search result.
