Smart Client scripts settings
Smart Client scripts let you automate workflows and start workstations in a predefined state. You can also automate view selection, tab switching, and more. This helps eliminate repetitive steps and reduce operator error during shift handovers or system reboots.
Select Verify script before deploying to see if the script can run on your system. This opens a new window and checks the .scs file against your smart client.
Select Generate script reference to see all script actions supported by your system. This creates an .md file and saves it locally. If you select Include configuration items, you get a named list of system-specific views, outputs, events, presets, and MIP plugin actions. Otherwise, they are summarized by group.
