Settings on the Exports tab
Version2026 R2
LanguageEnglish
Name
Description
Export list
Lists the items selected for export, for example video sequences.
For each item, you can change the time span by clicking the start time or the end time. After selecting a new date and time, click Go To. You can also change the time span by dragging the handles underneath the preview area.
Click an item to see a preview of the sequence in the preview area.
You can remove an item from the Export list list by clicking the Remove icon SC_Exports_RemoveItem_icon.png next to it. If you want to split the item into two, click the Split icon SC_DivideCameraIntoSequences_icon.png in the preview area.
Add item
Use the Add item button to select other items that you want to include in the export.
Remove all
Use the Remove all button to clear the Export list.
Export name
The program automatically fills this in with the local date and time, but you can rename it.
Export destination
Path - when you specify a path, the folders you specify do not have to be existing ones. If they do not already exist, they are created automatically.
A path may already be suggested in this field.
Media burner - you can specify a burner that you want to send the export to. In this way, you create the export and make sure it is written directly to an optical media in one go.
Privacy mask
Click to add privacy masks to the video. The privacy masks cover the selected area with a solid, black area.
The privacy masks that you add here only apply to the current export and for the selected video. The export may already include video with privacy masks configured by your system administrator. For more information, see Privacy masking.
