Set default level for buildings (Smart Map)
Version2026 R2
LanguageEnglish
If a particular level in a building is more relevant than others, for example the ground floor, you can set that level as the default level. When you open your smart map and go to the building, automatically the default level is selected.
If you navigate away from the building and back, XProtect Smart Client brings you to the level where you left off.
Steps:
  1. Navigate to the building on your smart map. If necessary, zoom in.
  2. Select the building. A pane appears on the right-hand side showing you the levels of the building. The default level is highlighted.
  3. Click Setup to enter setup mode. Notice the asterisk SC_MapS_SetDefaultLevelBuildings.jpg. It indicates where the current default level is.
  4. On the level you want to set as the default level, click the dots SC_MapS_AddRemoveLevels.jpg.
  5. Select Set as default.
  6. Select Setup again to exit setup mode and save your changes.
