Select another open view and then a view item
Version2026 R2
LanguageEnglish
If you have multiple views open, you can easily switch between them with the mouse or the keyboard. You can also combine the selection options. For example, select the view with your mouse and then select the view item with one of the keyboard options.
Do one of the following:
Select a view and then a view item.
If you have a view with a shortcut number, press * + [shortcut number] + Enter on the numeric keypad to select it.
Select the relevant view item with the arrow keys 2, 4, 6, and 8 on the numeric keyboard.
Press Alt and all open views are given a number.
Press the number for the view you want to select and then all view items in the selected view is given a number.
Press the number for the view item you want to select.
