Search settings
Version2026 R2
LanguageEnglish
The search settings let you customize the behavior of parts of the search functionality, mainly on the Search tab.
Name
Description
Auto-play video clip in preview area
By default, when you select a search result, video in the preview area is paused at the event time. To make it start playing automatically, select Yes.
Loop video clip in preview area
By default, when you preview video from a search result, the video sequence is played back only once. To make it loop, select Yes.
